What to know
The Sense Home app got disconnected from your electric meter during setup.
What to do
The two most likely causes for this error are:
- You (or the device) moved away from the meter as the connection was being made. Try again, and remain within 5-15 feet of the meter while allowing some minutes for the pairing to complete.
- Your device Wi-Fi turned off.
- Make sure your Wi-Fi is ON in your device's settings.
- There was an issue keeping your meter AP (Access Point) in pairing mode.
- Try Again - Your mobile device will re-attempt the pairing process with the meter.
This article offers advice on ways to resolve or extend Wi-Fi coverage, which can often solve the problem and improve your home's Wi-Fi performance in many ways. And for information on router settings, see What Wi-Fi router settings does Sense need?
