Will Sense work with my solar panels?
Most likely! Your incoming solar feed must connect directly into your main electrical panel, either through a breaker or a service-side tap. If solar is set up in a subpanel, the incoming solar feed must be within 46" of the main panel. This will allow the current sensor cable to reach and connect to the Sense monitor in the main electrical panel.
To have clean solar production readings, there should not be any other live circuits connected to the subpanel.
Sense Solar is available for purchase here!
If you aren't sure if your particular setup will work, please contact our support team.
