Why can’t I see any bubbles yet?
Over the first few days after your Sense monitor is installed, it will be listening to identify your first devices and your Always On load. While Sense is learning about your home for the first time, you won’t see any Bubbles in the Now view. However, you should still have full access to the Power Meter, so you can start walking through your home and turning devices on and off to identify how much energy they use — all in real time! You can access your Power Meter by tapping the Trends button in the navigation bar. Just scroll down to the bottom of the Trends page and tap the Power Meter card to check it out.
