If your Sense Monitor is not currently using the middle port for 400A Split Service or Generator monitoring, you can add solar sensors to your existing Sense Monitor for $50.
Before you purchase, check to see if Sense will work with your solar panels.
If you aren't sure if your particular solar setup will work with the Sense Monitor, please contact our Support team.
