You'll receive a timeline notification if we've detected a problem with your CT sensors in your second panel.
One (or both) of the sensors in your second panel may not be fully closed or may have partially opened when the panel cover was replaced.
To fix this, the sensors’ position needs to be adjusted such that the handle/trigger end of the sensor won’t be disturbed by other wires or the electrical panel cover. Without fixing this setup issue, Sense will not be able to correctly identify devices.
We highly recommend you contact an electrician to help resolve this issue. For questions, please reach out to the Support team.
