With our expanded 400A Split Service compatibility, Sense can now monitor 400A split service systems via an additional set of CT sensors.
If you are a Sense user moving from two monitors to one monitor with 400A monitoring, you will now see your aggregated home data in one account without the need to switch accounts. However, do note that you will lose the devices detected by the removed monitor; data from two monitors cannot be merged and detection parity cannot be guaranteed after uninstalling your second monitor.
Sense users moving from two monitors to one monitor with 400A monitoring are eligible for discounted CTs for a limited time.
To purchase Sense Flex add-on sensors or extension cables, click here.
