Grabbing your data from the web app is simple. You can access the export feature in two ways.
- For a global look into your energy usage, you can access it directly in the Dashboard screen.
- For a device-specific look into your energy usage, you can access it via a device’s Dashboard card in the Devices screen.
From there, just navigate to the time period you want, no different than your normal interaction with Usage and Dashboard. Once you’ve decided on the time period you’d like to export, click the “export” icon in the top right corner. You’ll get a popup that lets you choose the time interval of either “hour” or “day.”
Whether you’re exporting your global usage or the usage of a specific device, the exported .csv file will include the wattage for each time interval, including both average wattage and kWh. If you’ve chosen to export your global usage, you’ll also see your total wattage as well as every individual detected device, Always On, and, if relevant, your solar production. From there, the sky’s the limit!
Click on the export icon on the top right of the page:
Select the interval (day or hour):
