⚠️ What’s Happening
LG discontinued support for their LG EnerVu2 app in 2022. As a result, Sense will disable data sharing with the LG EnerVu2 app on August 6, 2025.
If you’ve linked your Sense monitor to the LG EnerVu2 app:
The integration will be set to "disabled" on August 6, 2025, and then removed entirely.
After that, LG EnerVu2 may show consumption data equal to production data, due to the absence of Sense input.
✅ What You Should Do
To avoid confusion or incorrect data in LG EnerVu2:
Remove the Sense monitor integration from your LG EnerVu2 app before August 6, 2025.
Check out LG’s FAQ page for more information about this change.
Note:
New users will no longer be able to link their Sense monitor to the LG EnerVu2 app.
The option may still appear in the app, but should be disregarded, as LG is no longer updating the platform.
