Note: The Sense Home Monitor should be installed by an electrician or qualified professional, and should be installed in compliance with all applicable local codes.
Installing Sense is very straightforward and generally takes a licensed electrician less than half an hour to complete.
When speaking with your electrician, let them know that Sense is an energy monitor that installs in your electrical panel with two clamp-on current sensors around the mains, and a 240V breaker which Sense uses for its power supply and also to measure voltage on both legs. Unless you have a spare 240V breaker in your panel, your electrician will likely need to provide a new one.
A set of installation instructions is also included in the package and in our Help Center. We provide an Installation Video, below.
NOTES:
- Si vous souhaitez obtenir une version en français du guide d’installation, il se trouve ici.
- If necessary, you can install your Sense monitor outside of your electrical panel. Refer to our external monitor installation instructions.
- For a recessed electrical panel that is flush mounted with your wall, see our recessed panel installation instructions.
- If you are unsure of whether Sense is compatible with your electrical panel configuration? Take a look at our compatibility guidelines.
