Your licensed electrician can connect a pair of Sense Flex add-on sensors into the middle-port of the Sense monitor, then install to track one of the following:
To purchase Sense Flex add-on sensors, click here.
Note: In the past, these have been called “Solar Sensors”, as they were originally used to support solar monitoring, but can now be used for different applications. Flex add-on sensors are our split-core sensors intended for multiple energy monitoring uses, not a Rogowski coil.
