Knowledge Base · Sense for Utilities
Overview
If you've heard about Sense through your utility provider, and you're waiting for access, this article explains how the rollout works, what to expect, and what (if anything) you need to do while you wait.
What you need to do:
There's no need to keep checking in on availability. When Sense becomes available for your home, we'll notify you directly; no action or follow-up is required on your end in the meantime.
If you'd like to check on your own, you can use the Sense eligibility checker to see whether your smart meter is currently Sense-ready: sense.com/eligibility. We appreciate your patience as firmware updates continue to roll out.
How the rollout works
The Sense rollout is not done area by area. Instead of a neighborhood-by-neighborhood schedule, we enable availability per home as the rollout progresses in coordination with your utility provider.
Because of this, we do not currently have a foreseeable date for when Sense will be available for a specific home or when a specific customer will be able to onboard with their meter. We know that isn't the answer anyone hopes for, but we'd rather be honest than set an expectation we can't meet.
Your electric service is not affected
Waiting on a firmware update does not affect the normal operation of your smart meter or your electric service. This is only about when the Sense Home app can connect to your meter.
Everyone involved, Sense and your utility provider, is doing their best to ensure the rollout makes it to your home promptly. You will be notified directly as soon as Sense is available in your home.
Because of this, we do not currently have a foreseeable date for when Sense will be available for a specific home or when a specific customer will be able to onboard with their meter. We know that isn't the answer anyone hopes for; we know it can be disappointing, especially if you're eager to explore more about your electricity use. But we'd rather be honest than set an expectation we can't meet.
What happens once you're notified
When your home is enabled, onboarding your meter is quick, and our Sense support team will be available to help if you need anything via our Sense Home App.
Quick reference
| Question | Answer |
| Is the rollout done area by area? | No, availability is enabled per home, not by neighborhood schedule. |
| When will Sense be available in my home? | There is no foreseeable date yet; you'll be notified directly once it's available. |
| Do I need to check in or follow up? | No, you'll be notified as soon as Sense is available in your home. |
| What happens when I'm notified? | You'll be able to set up Sense with your meter; support is available to help. |
| Why can't I connect the Sense Home app yet? | Your meter doesn't have the firmware version needed to connect yet. Firmware updates roll out in waves, with no set timeline for individual meters. |
| Does waiting for the update affect my electricity service? | No, your smart meter and electric service continue to operate normally. |
| Can I check if my meter is Sense-ready? | Yes, use the Sense eligibility checker at sense.com/eligibility. |
Still have questions?
If you have questions about your utility account, please contact your utility provider first. For questions about Sense itself, reach out to Sense Support, and we'll be glad to help.
