Yes. To deliver accurate, real-time energy insights, the Sense Home app relies on a stable and secure Wi-Fi connection to your Sense-enabled smart meter or installed Sense Home Energy Monitor. Ensuring your home's Wi-Fi is optimized is key to unlocking the full benefits of your Sense experience.
A Quick Wi-Fi Checklist
- Strong, Consistent Signal Strength: Your router or access point should ideally be located within approximately 20 feet of your Sense-enabled smart meter or electrical panel. If your router is farther away, or if there are dense walls or metal obstacles in between, consider using a Wi-Fi extender or a mesh network node to boost the signal strength at the installation point.
- A Configurable Router: You’ll need a router that supports network encryption and allows you to connect to the 2.4 GHz band. Sense operates exclusively on 2.4 GHz because it provides a much wider physical range and penetrates walls far better than 5 GHz (which is unsupported). Most routers purchased within the last three years easily meet these requirements.
- A Secure Network: Your Wi-Fi network must be password-protected (using security like WPA/WPA2).
Unsupported Networks
For reliability and data security reasons, the following connection types are not supported:
- Open Networks: Unencrypted, public, or password-free networks.
- Mobile Hotspots: Cell phone hotspots are not recommended due to bandwidth limitations and connection instability.
- Captive Portals: Enterprise or public networks that require you to log in via a web splash page or landing page (common in some apartment complexes, hotels, or dorms).
Connection Troubleshooting Tips
- Disable VPNs Temporarily: When setting up your Sense account and linking your hardware for the first time, temporarily disable any VPNs, active mobile hotspots, or airplane mode settings on your smartphone to avoid setup interference.
- Check Dual-Band Settings: If you use a modern dual-band router that shares a single network name (SSID) for both 2.4 GHz and 5 GHz, ensure the router can successfully assign your smart meter or monitor to the 2.4 GHz band. If you run into issues, you may need to temporarily separate the bands in your router's admin settings during pairing.
- Seek ISP Help if Needed: If you are unsure how to adjust your network settings, contact your Internet Service Provider (ISP). They can help confirm your router is up-to-date and correctly configured for smart home devices like Sense.
To learn more about optimizing your network for Sense, check out:
👉 Wi-Fi Requirements For The Sense Home App
